Toughram XG RGB White: Thermaltake’s ram goes white!
Thermaltake announces new memory kits. No, we are not talking about RAM in DDR5, but DDR4. The brand offers its Toughram XG RGB White kits, a white version of existing kits.
Toughram XG RGB White: all white memory for Thermaltake!
Thermaltake Toughram XG RGB WhiteWith this white series, the brand offers many configurations in terms of speed or capacity. Indeed, we find kits in 16 GB, 32 GB and 64 GB. In terms of frequency, TT announces 3600 MHz, 4000 MHz, 4400 MHz and 4600 MHz. The timings will vary according to the capacity of the kit and its frequency. Ditto for the voltage which will be between 1.35V and 1.5V.
On the design side, we find the same two-tone heatsink as the black version. The same goes for the RGB lighting, which is always present on the top of the strip. For the management, we can use the TT RGB Plus software. However, beware of the dimensions of the kit that could cause compatibility problems with some fans.
For prices, we already find these kits on the store online the brand. The bill starts at $139.99 for the kit in 2x 8 GB at 3600 MHz. This last one will be able to reach $549,99 for the one in 4000 MHz in 64 Go!
This way to the Thermaltake datasheet !
