Toughpower PF3 Platinum : Thermaltake ATX 3.0 PSU
Thermaltake launches a new series of power supplies with the Toughpower PF3 Platinum. We find blocks with a big certification, and a conformity with the ATX 3 .0 standard !
Toughpower PF3 Platinum: power supplies from 750W to 1200W!
With this new series, we find a total of four power supplies. In terms of power, we have power supplies with 750W, 850W, 1050W and 1200W for the most powerful model. The performance should be good too, since we find a certification 80+ Platinum. This assures us of an efficiency of 94% at 50% load.
Thermaltake Toughpower PF3
Otherwise, we have the right to compact blocks, even in 1200W of power. The casing is indeed very short since it is 14 cm deep! Clearly, it is a pleasure, we will be able to have a power supply of big power while keeping a certain space in the case.
Internally, the cooling is provided by a 120 mm fan with semi-passive operation. Via a switch, we can force the active operation, otherwise, it will start only from 40% of load.
As for the electrical part, we have the right to a single 12V rail. This is coupled with a very low noise on the different rails <30 mV. Similarly, the regulation of voltages is very strict with variations ‘±2%. Finally, we can count on the use of 100% Japanese capacitors and a fully modular cable management. Of course, the famous 16-pin 12VHPWR connector is part of the package!
Concerning the prices, the brand announces :
  • 189,90 € the 750W block
  • 209,90 € the 850W block
  • 249,90 € 1050W power supply
  • 274,90 € the 1200W block
Here are the technical data sheets of Thermaltake!
