Definitely, after a version green and turquoise version, the ToughFan from Thermaltake continues to be declined. This time, Thermaltake announces its Toughfan White Edition, a color that will concern the 120 mm and 140 mm versions. Especially since the mill is declined in “High Static-Pressure”.
Toughfan White Edition: a new color for the Thermaltake fan!
The fan in question, we know it rather well since we tested its green version at this address. In addition, we recall that it has a total of nine blades passing very close to the frame. This is why the motor has been reinforced, as well as the material used (LCP). With this, we find a frame equipped with silentblocks.
From a characteristic point of view, this version will work from 500 RPM to 2000 RPM via a PWM power supply. At full speed, the airflow will reach 58.35 CFM and the static pressure will be 2.41 mmH2O.
The 140 mm version will operate at the same speeds: 500 RPM to 2000 RPM. On the other hand, the air flow and the static pressure increase. These values reach 119.1 CFM and 3.54 mmH2O.
For the price, it will be necessary to count $24,99 for the model in 120 mm against $29,99 for the version in 140 mm. Prices that are in line with the other colors!
Here is the Thermaltake datasheet !
