Toughair 510: Turquoise and Racing Green versions at Thermaltake!
Originally, Thermaltake’s Toughair 510 heatsink was a single-tower fan that came in gray and black. Now, the brand offers Turquoise and Racing Green versions, in line with the new colors of the Toughfan 12 fans!
Toughair 510: color from Thermaltake!
Thermaltake Toughair 510 In fact, Thermaltake offers two new variants based on the original Toughair 510. This means that the heatsink is equipped with two Toughfan 12 fans in Turquoise and Racing Green. As a reminder, these are the new colors offered by the brand.
As a reminder, the heatsink is rather compact since it has dimensions of 123.6 (W) x 98.8 (D) x 159.5 (H) mm. With this, there are a total of four copper heatpipes of 6 mm each. However, no copper base here, the heatpipes come into direct contact with the CPU.
As for the ventilation, as we said, there are two colored Toughfan 12 fans. Powered by PWM, the mills will run from 500 RPM to 2000 RPM. At full speed, the airflow will be 58.35 CFM when the static pressure reaches 2.41 mmH2O. By the way, we proposed you a test at this address. For the moment, the price is not known, too bad.
Here and there  are the Thermaltake datasheets !
