A little tour at Thermalright who announces a new fan. Indeed, the manufacturer offers us its TL-B9, a small fan in 92 mm. A format that can be mounted on compact fans or even on the back of a NR200P signed Cooler Master for example.
TL-B9 : a small fan by Thermalright !
With its new fan, the brand offers a very small reference in 92 mm. Regarding its colors, we have something quite sober, all in shades of gray with lighter or darker colors. We will also note the presence of silentblocks at each corner of the frame!
Regarding its characteristics, this model has a PWM power supply. At full speed, it will go up quite fast with 2500 RPM. On the other hand, considering the format, it will not necessarily rhyme with an extreme noise either. As for its airflow, at full speed, it will generate a flow of up to 54 CFM. Finally, the static pressure will reach 2.24 mmH2O.
The accessory part seems rather complete for a fan. The brand provides several sets of screws of different lengths as well as rubber washers and nuts. Similarly, there is even a splitter to limit the number of occupied fan sockets on your motherboard.
For the moment, we don’t know its price yet. Nevertheless, we can say that a white version is also proposed.
Go here and here for Thermalright’s technical data sheets !
