Thunder Panoramic: an aquarium housing from SuperFlower
As for SuperFlower, we’ll highlight the announcement of their latest case, the Thunder Panoramic. This model features an aquarium-style design with no visible front pillars. It also offers a compartmentalized layout… In short, the standard case of 2026.
Thunder Panoramic: a new case from SuperFlower!
SuperFlower Thunder Panoramic
As it turns out, while SuperFlower is known for its power supplies, the manufacturer also offers a range of cases. This lineup is now getting a new model that adopts a mainstream design, as we can see. Indeed, it features a glass front panel paired with a side panel. The unit also features a dual-chamber design.
Regarding component compatibility, you’ll need to refer to a product listing on Newegg, as the manufacturer’s website doesn’t list this case yet. From this, we learn that this case is compatible with ATX-format motherboards at most. Furthermore, it should also be able to accommodate motherboards with reversed connectors, given the openings on its motherboard tray. Otherwise, it supports CPU coolers up to 160 mm in height, while graphics cards can measure up to 415 mm in length.
In terms of cooling, we learn that this model comes with four pre-installed RGB fans. To complement the ventilation, there are six 120mm fan slots distributed across the top and bottom. As for water cooling, 360mm radiators should be able to be mounted without much difficulty.
Finally, regarding storage, there is a tray capable of accommodating two 2.5-inch drives and one 3.5-inch drive simultaneously. The 3.5-inch drive bay is located at the rear of the case, beneath the power supply bay.
As for the price, this model is available on NewEgg for $259.99… However, the case is sold as a bundle with a 1000W Leadex III Gold ATX 3.1 power supply. If we subtract the price of the power supply, that brings the case down to roughly $110.
