Thermaltake launches its CTE C750 box!
Thermaltake officially launches its CTE C750 series of cases, a range of four models. We find the Air versions in black and white as well as the TG aRGB versions in black and white. Anyway, it’s a PC case designed to host custom watercooling loops !
CTE C750 : four cases for Thermaltake !
Thermaltake CTE C750 TG aRGB
With these new cases, the brand does not make lace and proposes imposing references. Indeed, the chassis has dimensions of 327 (W) x 599.2 (D) x 565.2 (H) mm. The weight is also consequent with 16.7 kg, once the PC is assembled, expect a machine of more than 20 kg!
However, these dimensions allow the integration of motherboards in E-ATX format. Likewise, there is plenty of room for the graphics card: 370 mm with radiators, 420 mm without. On the power supply side, we find 220 mm against 190 mm for the CPU cooling unit. Nevertheless, this case is clearly designed for watercooling since it supports 420 mm AIO radiators. In custom, we go on 360 mm at the back, front, bottom and next to the motherboard!
Also the ventilation can be consequent. With slots at the front, rear, bottom, side and top, we have a total of fourteen slots in 120/140 mm! If desired, we can even switch to 200 mm at the front and rear with two slots.
Thermaltake CTE C750 Air
Clearly, this is a case optimized for cooling and airflow. Especially since the configuration is oriented at 90° with graphics cards pointing downwards. Moreover, if needed, up to seven 3.5″ hard disks or fourteen 2.5″ SSDs can be mounted, but this will condemn fan/radiator slots.
Currently, no price is known, too bad.
Here are the technical data sheets of Thermaltake !
