Thermaltake launched its Swafan EX12 and EX14 fans at CES!
Thermaltake took advantage of CES to launch a new range of fans on the market. This time, it is about Swafan EX12 and EX14, mills with interchangeable blades. Nevertheless, this version comes with a connector directly integrated in the frame for a serial connection!
Swafan EX12 & EX14: fans with interchangeable blades!
Thermaltake Swafan EX12As a reminder, Thermaltake ‘s Swafan fans are mills with interchangeable blades launched in August 2022. The family is growing with the arrival of the EX12 and EX14 models that bring their share of novelty.
Of course, the principle remains unchanged with two sets of blades provided. Without changing the orientation of the fan, we will have blades for the push and others for the pull. Moreover, this makes cleaning much easier as you just have to remove them to remove the dust that has accumulated over time.
However, the novelty will concern the new connector, magnetic, proposed by the brand. The latter will also allow the fans to be connected in series through the frame, which is practical for lightening the installation of cables. Of course, the RGB is part of the game with a hub and an illuminated hoop at the frame.
On the specs side, we have :
  • 120 mm (from 500 RPM to 2000 RPM) :
    • Standard blades :
      • Airflow: 57.11 CFM
      • Static pressure: 2.39 mmH2O
    • Reverse blades :
      • Airflow: 56.26 CFM
      • Static pressure: 2.02 mmH2O
  • 140 mm (from 500 RPM to 2000 RPM):
    • Standard blades :
      • Air flow: 81.6 CFM
      • Static pressure: 3.17 mmH2O
    • Reverse blades :
      • Air flow: 79.3 CFM
      • Static pressure: 2.73 mmH2O
For now, the price is not yet known, however, keep in mind that the first models were already priced at $119.99 in a pack of 3 in 120 mm against $129.99 in 140 mm!
This way to the Thermaltake data sheet !
