Thermaltake announces the ASTRIA 600 ARGB CPU cooler
Thermaltake announces the ASTRIA 600 ARGB CPU cooler. A dual-fin CPU cooler. The ASTRIA 600 is the heaviest model, with the largest heat dissipation surface thanks to its dual-tower design.
thermaltake ASTRIA 600 ARGB
Ventirad information
Its design involves a nickel-plated copper base. It features six 6 mm-thick copper heat pipes. The two stacks of fins are topped by a die-cast metal top plate with ARGB lighting of 18 LEDs each. For cooling, it has two 120 mm fans.
The ventirad in detail
Each of the two included 120 mm fans is equipped with a 40,000-hour bearing. The fan supports 4-pin PWM for its main function. It runs at speeds ranging from 500 to 1,800 RPM, pushing up to 65 CFM of airflow, 2.56 mm Hâ‚‚O of static pressure, and up to 26.8 dBA of noise. Thermaltake says there’s room for memory modules 1.5 times the height (even with both fans in place). The cooler has a cooling capacity of 265 W.
Compatibility and dimensions
Compatible with the following sockets:
  • INTEL: LGA 2066/2011/1700/1200/1156/1155/1151/1150.
  • AMD: AM5/AM4.
The cooler measures 124 mm x 137 mm x 160 mm (L x W x H).
For more information on the THERMALTAKE cooler: click here.
The company has not revealed a price.
