Themis II : a Raijintek fan with five direct touch heatpipes !
Small novelty signed Raijintek since the brand announces an aircooling type heatsink. This new model, named Themis II, offers a single tower format in 120 mm. Nevertheless, what will hold our attention, it is its numerous heatpipes in direct contact.
Themis II : five heatpipes in direct contact with the CPU !
Raijintek Themis II With this cooler, Raijintek offers us a heatsink with a rather basic finish. Indeed, the fins are gray and the heatpipes are made of non-anodized copper. However, it can count on a fan with a rather nice design in our opinion.
At the level of the radiator, we find a total of five copper heat pipes of 6 mm each. It is actually quite funny that Raijintek chose such a configuration. Once we reach a certain number of heatpipes, we generally find a copper base.
As for the fan, it is a 120 mm model, classic. It offers a PWM type power supply and has an operating range between 800 RPM and 1600 RPM. At full speed, the air flow will be 72 CFM and the static pressure of 2.16 mmH2O.
Finally, as far as sockets are concerned, we note that it is Alder Lake-S “ready” since it is LGA-1700 compatible. Otherwise, for the installation in cases, there should be no big problems with its 155 mm height. The same goes for the RAM with its 75 mm thickness.
All we need is the price.
This way to the Raijintek datasheet !
