The AN600, DeepCool’s little top flow, is out!
The AN600 is a small cpu cooler in top-flow format which was already the subject of a news item in June. This time, it’s official: DeepCool is launching its little cooler. Although the price is known, we’ll have to wait a little longer before seeing it in stores.
AN600: a top flow with a slim fan!
DeepCool AN600As a reminder, with this heatsink, the brand is targeting compact or even ITX cases. In fact, the dimensions are contained and the heatsink measures 122 (W) x 120 (D) x 67 (H) mm. Weight is also measured at less than 700g on the scale.
The heatsink itself features a total of 6 copper heat pipes, each 6 mm in diameter. They join at the base, which is also made of nickel-plated copper. What’s more, once installed, depending on the direction, you’ll find a clearance of 40 mm for the RAM or 42 mm for the motherboard I/O cover.
Ventilation is provided by a slim 120 mm fan. This fan uses a PWM power supply and runs from 500 RPM to 1850 RPM. At full speed, the airflow generated is 61.56 CFM, while static pressure is 1.97 mmAq.
For the price, you’ll have to fork out a small bill of $54.99 or around fifty euros.
Click here for the DeepCool product sheet!
