TG4M : Sharkoon case with RGB and glass for 75 € !
New case from Sharkoon which announces a TG4M, a new medium tower model. You will see, it has some arguments for him, including the price which is very interesting.
TG4M: four bright fans and a glass panel for 75 €!
Sharkoon TG4MWith this new case, the brand signs a medium tower reference with dimensions of 200 (W) x 455 (D) x 430 (H) mm. The front panel is made of mesh to let the ventilation breathe and there is a tempered glass side panel. Nevertheless, we feel that this model aims at an affordable price since there is no power supply cover.
Inside, we will have a motherboard tray that can accommodate a model in ATX format at the largest. Otherwise, we have six expansion slots. Via these, we will be able to install a 375 mm long graphics card. Regarding the CPU fans, we will have to make do with a maximum height of 160 mm. Finally, for the power supply, the ATX blocks of 265 mm will fit without difficulty.
The cooling section features four RGB fans as standard. Three of them are present on the front and the last one is installed at the back. However, for the watercooling, it is difficult to say, the sheet does not mention any compatibility.
Finally, you should know that there are two 3.5″ slots and four 2.5″ slots for storage. The case also includes a small RGB controller to manage the lighting of the four fans.
For the price, as we said, we are on a base of 75 € which is not excessive either.
Here is the technical sheet of Sharkoon!
