TD300: another case from Cooler Master!
In addition to the HAF 500 which we talked about on Friday, Cooler Master announced another model: the TD300. It is a mid-range model with a mesh front so that it breathes better… In addition, it has a compact size for micro-ATX cards.
TD300 : again mesh in the front panel !
Cooler Master TD300With its dimensions of 210 (W) x 433 (D) x 420.5 (H) mm, this model is intended for compact systems. Indeed, the brand announces a case compatible with motherboards in micro-ATX format. On the other hand, for the rest of the components, there are no real restrictions. The graphics card can be up to 344 mm long and the CPU cooling unit is 166 mm high. Finally, for the power supply, 140 cm of depth are free, even 325 mm without HDD cage.
The cooling part integrates two 120 mm mills in the front panel. They are placed in aspiration and will bring fresh air to your system via the mesh front panel. If you wish, it will be possible to complete this ventilation: two fans at the top and one at the back. As for watercooling, this model accepts 280 mm radiators in the top and in the front. Moreover, to facilitate the assembly, the top panel is removable.
Finally, we finish with the storage which includes two 3.5″ slots and two others in 2.5″.
In terms of price, this model remains rather affordable since it is less than 100 €: 89.99 € precisely!
Here is the Cooler Master datasheet!
