TB560-BTC Pro: 12 PCIe slots for the mining motherboard from Biostar!
If your goal is to mine cryptocurrencies with GPUs, the latest motherboard from Biostar should interest you. Indeed, the brand unveils its TB560-BTC Pro, a card with 12 PCIe connectors!
TB560-BTC Pro: enough to connect 12 graphics cards!
Biostar TB560-BTC ProThe board comes in a rather special format, with dimensions of 30.4 cm x 21 cm. The same goes for its power supply part where you can see two 24-pin ATX connectors and an 8-pin EPS12V.
The particularity of this card is to offer 12 PCIe connectors. 11 of them are x1 ports to the 3.0 standard. The last one is a PCIe x16 working to the 4.0 standard since it is connected directly to the processor.
As for the rest, we are faced with a rather classic card featuring four SATA III and one M.2 PCIe 4.0 x4 for storage. Concerning the RAM, we have two memory slots in DDR4-2933. Finally, the socket is an LGA-1200 coupled with a B560 chipset, a card designed for 11th and 10th generation Core i.
Unfortunately, the selling price is not yet known for this model.
Biostar’s datasheet is here!
