TeamGroup announces a new watercooling kit with its T-Force Siren CPU/SSD. However, this model leaves a lot of questions unanswered since the specification sheet is simply not revealed.
T-Force Siren CPU/SSD: an AIO for CPU and SSD!
TeamGroup has announced a new AIO from its T-Force Siren series. However, it is intended for CPU and SSD cooling. Moreover, the technical data sheet is still unknown, so we’re going blind on this one… In fact, one of the few things put forward by the brand: RGB lighting…
Otherwise, the kit illustration shows one block for the SSD (M.2 2280) and a second one for the CPU. By the way, TeamGroup talks about compatibility with Intel LGA-1700 and AMD AM5 sockets, so future platforms will be well supported.
However, what we do not know is whether the kit will include a radiator or not. In itself, it’s not impossible that the brand decides not to display it in order to emphasize the cooling of the SSD and the CPU. If this is the case, we can expect a 240mm kit at least according to El Chapuzas Informatico.
Now we just have to wait for the rest of the information from the brand to know where we are going!
