Enermax announces a new case to accommodate your gaming configurations. Indeed, it announces the arrival of its StarryKnight SK30, a model with a complete basic ventilation: four fans are part of it!
StarryKnight SK30: a case with four Squa fans from Enermax!
With this model, the brand Enermax announces a new model in medium tower format. As far as dimensions are concerned, it’s classic with 220 (W) x 465 (D) x 486 (H) mm. Internally, there is room for E-ATX, ATX, micro-ATX and mini-ITX motherboards.
For the rest of the components, Enermax announces :
- Power supply: 160 mm and up to 200 mm without HDD cage
- Graphics card: 405 mm
- CPU fan: 170 mm
Basic, the ventilation is complete with four Squa mills installed as standard. In addition, the front panel is made of mesh, which should allow a good supply of fresh air! Otherwise, as a reminder, Squa fans, we had a glimpse of what they were capable of in our test of the AquaFusion 120
. On the other hand, the case’s fans will not be as noisy as they were during the AIO test, we assure you.
Otherwise, this case will be able to accommodate watercooling radiator in 360 mm at the front, but also at the top. Concerning the ventilation, it will be possible to complete it by adding three mills in the top and two on the power supply cover.
The storage part puts forward two slots in 3.5″ also compatible 2.5″. Otherwise, it is the usual recipe with the presence of two small 2.5″ boards at the back of the motherboard tray.
Finally, this case features an RGB hub to centralize your lighting devices. Similarly, the graphics cards can be installed vertically. Otherwise, it takes advantage of a support to prevent them from bending under their own weight.
Finally, we end with the selling price which should be around 130 €.
Here is the Enermax datasheet !
