SP850: a Lian Li SFX power supply with 12VHPWR!
Lian Li has just announced a new small power supply with its SP850. On the program, we find a block in SFX format with a power of 850W. Nevertheless, the particularity of this reference is to have a 12VHPWR connector.
SP850: a SFX model with 12VHPWR connector!
Lian Li SP850In the program, we find a very small power supply with a power of 850W. With this, we have the right to an 80+ Gold certification as well as a fully modular cable management. Moreover, it is at this level that the brand distinguishes itself since it integrates a 12VHPWR 12+4 pins connector.
Internally, we have the right to capacitors of Japanese origin. The PFC is active and the power correction factor is 90%. Finally, the ventilation is provided by a 92 mm mill with semi-passive operation, and this, up to 40% load. And as for the electrical protections, we find the OCP,OVP,OTP, SCP and UVP.
Regarding the connectivity, we have enough to do with a 24-pin ATX and two EPS12V 4+4 pins. For the graphics part, we have three PCIe 6+2 pins as well as a 12VHPWR in 12+4 pins. We finish with eight SATA and four Molex.
For the price, we will have to count on a bill between $150 and $170 with a five-year warranty. Also, the availability is already effective with black and white models.
Here is the technical data sheet from Lian Li!
