SK PWM D-RGB White: Phanteks also offers white fans!
In addition to its two cases the Phanteks brand announced the arrival of new fans. On the program, we find the SK PWM D-RGB White mills, case mills that also land in white.
SK PWM D-RGB White: white case fans!
Phanteks SK PWM D-RGB WhiteThe fans in question come in two sizes: 120 mm and 140 mm. As you can see, they remain quite basic, nevertheless we find particularly elongated blades as well as silentblocks at the four corners of the frame. An RGB lighting is also part of the game, on the central hub.
As for the more technical part, these fans benefit from a PWM power supply. Whether 120mm or 140mm, the rotation speed remains the same: 500 RPM to 1500 RPM. Of course, the larger model has a higher airflow: 84.5 CFM against 50 CFM. Same for the static pressure which will be a little better: 1.23 mmH2O against 0.96 mmH2O, on this subject, it does not push very hard.
We finish with a small word on the selling price which is rather affordable. Indeed, Phanteks announces its fans at 34,90 € in pack of three in 120 mm against 39,90 € in pack of three in 140 mm.
Go here and here for Phanteks’ technical data sheets!
