Siren GD240E: TeamGroup’s AIO will be rather affordable!
Let’s go back to the hardware we talked about last time September last. Indeed, TeamGroup has just announced the prices of its AIO Siren GD240E and it turns out that they are rather affordable… But we’ll come back to that at the end of the article. In between, let’s have a little reminder.
Siren GD240E: a rather affordable AIO!
TeamGroup Siren GD240EWith these new kits, TeamGroup offers us two watercooling kits in 240 mm, one in white, the other in black. Anyway, these two models offer RGB lighting on the fans and the pump… Well, on the waterblock since the pump is directly integrated into the radiator.
Speaking of waterblock, you should know that this part has dimensions of 65.5 mm in diameter for a height of 49 mm. The base will also be in copper. As for the pump, all the figures are not known. We just know that it will turn up to 4000 RPM at full speed.
Finally, the cooling is ensured by two fans of 120 mm powered by PWM. They have a rotation range between 600 RPM and 2000 RPM and generate an airflow of 78.73 CFM and a static pressure of 2.39 mmH2O.
In the end, the pricing turns out to be a nice surprise as they are officially announced at $109.99!
Here is the TeamGroup datasheet!
