Silencio S400 White: new color for Cooler Master’s case
Via the Japanese branch of Cooler Master, we learn that the Silencio S400 of the brand is available in white. As a reminder, the Silencio series is a range of cases oriented silence with front door and a sober and pure design!
Silencio S400 : here it is in white !
Cooler Master Silencio S400 WhiteWith this new version, the brand puts forward a mini-tower box measuring 210 (W) x 418 (D) x 408 (H) mm.
Internally, there will be enough space to install a motherboard in micro-ATX format at most. Otherwise, we will have 319 mm of length for a graphics card and up to 167/166 mm for the CPU cooling unit. The model with a steel panel allows the installation of a slightly larger cooling unit. Finally, on the power supply side, we have between 166 mm and 325 mm deep, depending on whether or not we keep the HDD cage positioned in front!
As for the storage, we find a 5.25″ slot and four 3.5″/2.5″ slots.
For cooling, we have, as standard, two fans in 120 mm, CF120. Otherwise, two slots in 120/140 mm are present in the front, ditto in the top. At the back, it’s classic: 120 mm only. Of course, all this does not help the compatibility with watercooling radiators since we are limited with 280 mm in front and provided that the 5.25″ bay is removed. The same goes for the top, if you want to install a 240mm radiator, you will have to remove the ODD(Optical Disc Drive) slot.
At the moment, we have no information on the sales prices. Nevertheless, we imagine that they will be quite similar to the black version that you can find above.
Here is the Cooler Master (Japan) datasheet !
