Sharkoon Rebel C60, two glass panels and a mid-range price!
After the ASUS model, we return to the world of PC cases with the Sharkoon brand. Sharkoon has announced its Rebel C60 model, available in black or white. The little plus in the story is the average price and the presence of two glass panels!
Rebel C60: a clear view of the configuration!
Sharkoon Rebel C60With this model, Sharkoon offers us a case with two glass panels, one on the front, the other on the side. Naturally, this configuration gives a clear view of the configuration. Nevertheless, we’re not at the stage of pillarless cases like the NZXT H6 or Hyte’s Y40/60.
Nevertheless, there’s enough space to mount a fairly decent configuration. The C60 will accommodate an ATX motherboard or a 40 cm-long graphics card. As for the air cooling cooler, it can measure up to 165 mm in height.
The ventilation features four 120 mm fans with RGB LEDs. These are fitted as standard at the rear of the case, at the bottom and on the side of the motherboard tray. If you wish, you’ll have four free slots: three at the top and one on the side panel.
As for watercooling, there’s a 360 mm radiator support at the top.
The price is quite reasonable, at around €114.
Here are the Sharkoon product sheets!
