Sharkoon offers its S series watercooling kits in white!
Some time ago Sharkoon presented its S series all-in-one watercooling kits. This range featured two 240 mm kits and one 360 mm kit. This time, the company is back with S80 and S90 versions in white!
S Series: Sharkoon’s AIOs go white!
Sharkoon S90 WhiteWith its S80 and S90 kits, the brand offers all-in-one watercooling systems in 240 mm and 360 mm. These feature two and three fans for radiator cooling. The radiator features aluminum construction and is 27.5 mm thick. The finish is neat, with right angles, although some screws are still visible.
The pump will feature an aRGB lighting system, but the finish is interesting, with a diamond-cut hoop. Of course, the base is made of copper, and the pump is powered by a PWM signal. The brand mentions its operating speed: from 1600 rpm to 3200 rpm.
Finally, as regards ventilation, we’ll be treated to two or three 120×25 mm fans. The latter also feature a PWM power supply. In terms of speed, the mills run from 600 rpm to 2000 rpm. At full speed, airflow will be 131.93 m3/h, while static pressure will reach 2.90 mmH2O.
Sharkoon S80 White
Last but not least, all this is compatible with Intel LGA-1000/2000 and AMD AMx/FMx/TR4 sockets and derivatives.
As for prices, the good news is that the entire series is available for purchase. Prices range from €83 to €134, depending on version and radiator size. That said, we’re still talking reasonable prices for a watercooling kit with RGB lighting.
Here are the Sharkoon datasheets!
