Shark Xtend: RGB cable extensions for Sharkoon!
Sharkoon launches new accessories to embellish your setup. Just like Lian Li’s Strimer sleeves, the brand launches its Shark Xtend cable extensions. As you may have guessed, they are sheathed cables strand by strand with aRGB lighting!
Shark Xtend: aRGB cable extensions!
Sharkoon Xtend 24In the program, the brand launches two products under this Xtend range. The first one is intended for the 24-pin ATX connector of the motherboard, the second one for the PCIe 6+2 connectors of the graphic cards. Note that for graphics cards, the extension is made of a dual connector 6+2 pins. In fact, it is a question of cables sheathed strand by strand in white color. However, they are surmounted by an appendix comprising small optical fibers in order to diffuse an aRGB lighting. To take advantage of the lighting, you will have to connect the cables to an aRGB connector on your motherboard. Sharkoon Xtend 16 Otherwise, we find rather decent lengths since the 24-pin cable is 24.5 cm long. For the PCIe part, we can count on a length of 30 cm. We end now with the selling price which is 34.90 € in 24 pins against 29.90 € in double PCIe 6+2 pins. This may seem expensive, however, it is to be compared with the offer of Lian Li (~55 € and ~54 € respectively).
Shark XTend 24 and Shark XTend 16 technical data sheets from Sharkoon
