Small tour at Sharkoon which announces the arrival of a new mechanical keyboard. On the program, the brand puts forward its SGK60, a model with Kailh switches, for a change. Moreover, its price is clearly not exaggerated!
SGK60: a mechanical keyboard with Kailh switches!
With this new model, the Sharkoon brand puts forward a 104 keys model. So, everything is there: navigation key and arrow pad in particular. We can also count on the addition of extra function keys.
The material also seems qualitative since we find aluminum for the cover plate. The latter also forms a wave on top, a shape that vaguely reminds us of the K70 from Corsair.
As we said, the brand opts for Kailh switches, Kailh box more precisely. They have the particularity of being resistant to dust. Here, three models are available:
- The red ones, linear: 45 g, accent point at 1.8 mm
- Browns, tactile: 45g, emphasis point 1.8mm
- Whites, clicky: 45g, emphasis point 1.8mm
Note also that each switch will have a long life of 80 million activations.
Otherwise, internally, we can count on the presence of an internal memory of 64 Kb. It will allow you to save your key profiles and lighting effects. Also, the polling rate is 1000 Hz and we can count on a game mode.
We will finish with the price which is 89.90 €, a rather sweet price for a mechanical keyboard… especially since at this price, the brand provides a set of 14 keys in PBT double injection.
Here is the technical sheet of Sharkoon !
