After the StarryKnight SK30 enermax model, we go on with another case, but this time, signed by Silverstone. The brand announces its Seta H1, a model with two 160 mm fans in front. Logically, it should blow well!
Seta H1: two 160 mm fans in front!
With this model, the brand offers a case with a mesh front panel with a light signature just behind. Design-wise, it looks pretty good, well, that’s just our opinion.
More concretely, the brand offers us a case with great compatibility regarding the motherboard. The latter will be able to go up to SSI-EEB format, enough to do. Nevertheless, this is justified by the dimensions of 232 (W) x 480 (D) x 494 (D) mm.
For the rest, we have clearances of :
- 182 mm for CPU cooling
- 250 mm for power supplies
- 394 mm for graphics cards
The storage part remains most basic with only two slots 2.5″ and 3.5″ via a cage located under the power supply cover.
The ventilation, as we told you, is composed of two 160 mm mills in front. However, these are supplemented by a 120 mm at the rear, always standard. Despite this, you can install up to three fans in 120/140 mm in the front and in the top. And as for watercooling, you can install 360 mm radiators in the front and top.
Finally, this Seta H1 is distinguished by the presence of multifunctional supports that will serve as storage support. It will also be possible to use them as a cable cover or as a tank support for custom watercooling. Let’s not forget to mention that the side window is mounted on hinges.
However, the pricing remains quite expensive since this reference is announced at ~$180!
This way to the Silverstone datasheet!
