Sama announces its V62 housing with curved glass
The SAMA brand also offers cases, in addition to its cooling solutions (tested here and there). Today, we learn that the company is announcing its new V62. It is a stylish case with an aquarium design, a panoramic view, and a tempered glass panel that is even curved!
V62: a SAMA case with curved glass!
SAMA V62
With this case, the brand offers us a model measuring 285 (H) x 475 (D) x 422 (H) mm. The construction is based on SPCC steel coupled with 4 mm thick tempered glass.
In terms of component compatibility, this model allows for the installation of ATX,micro-ATX, and mini-ITX motherboards, all with reversed connectors if necessary. The maximum height allowed for the CPU cooler is quite basic: 160 mm, no more, while the graphics card must not exceed 44.5 cm in length, which leaves some leeway. Finally, an ATX power supply unit with a length of 210 mm can be installed.
This case stands out above all for the number of fans installed as standard. In fact, in a V62, straight out of the box, the company installs six 120 mm fans! This leaves few options for adding more: 3x 120 mm at the top and that’s it. As for the water cooling radiator, there is a dual 360 mm model mount.
SAMA V62
To help manage the fans, SAMA has included a hub with nine fan connectors, enough to manage all the fans installed in the case. In addition, there are magnetic dust filters to help keep your setup as clean as possible.
Available in black or white, both versions of the case come at the same price of €99.90!
Check out the SAMA product sheet here!
