S400 Sakura: a limited edition Silencio case from Cooler Master!
New production by Cooler Master which announces the arrival of a new case. Our model of the day belongs to the Silencio series, a range of sober and silent cases. In short, here is the S400 Sakura in limited edition!
S400 Sakura: a Cooler Master case in micro-ATX format!
Cooler Master Silencio S400 Sakura Edition
With this new model, the brand offers a compact case measuring 210 (W) x 403.5 (D) x 400 (H) mm. These dimensions allow it to accommodate motherboards in mini-ITX and micro-ATX format to the maximum.
Nevertheless, inside, there is enough space to install a 166 mm CPU cooling unit. With this, GPUs will be able to measure up to 310 mm in length and the power supply up to 200 mm without HDD cage, 140 mm with.
Speaking of storage, this model features a total of four 3.5″ slots or four 2.5″ slots. In addition, a 5.25″ bay is included, which is hidden behind the front door of the case. Yes, it’s been a while since we’ve seen one on a case.
The ventilation shows a total of five slots in 120 mm, four in 140 mm. So, two of them are present in the front, two in the top and one in the back. For watercooling, this leaves us the possibility of installing radiator in 240/280 mm maximum. In addition, in the front, a removal of the 5.25″ cage may be necessary.
For the moment, we do not yet know its selling price. Similarly, we do not yet know how many copies are planned. On the other hand, it must be said, it looks pretty good with its various borders and Japanese cherry blossoms.
Here is the Cooler Master datasheet!
