RTX 3070 Vision: a sober and elegant card from Gigabyte!
You like pretty things? This new card signed Gigabyte should please you. Indeed, the brand offers us a really elegant RTX 3070 Vision. The card displays a fairing with an aluminum plating, which gives it a really elegant line!
RTX 3070 Vision: a truly elegant card from Gigabyte!
Gigabyte RTX 3070 Vision With this new card, the brand does not fall into the delusion of a large block that is impossible to fit into the PC. On the contrary, this model has a very reasonable thickness of 2.5 slots and a length of 28.6 cm.
Otherwise, we find a heatsink with five copper heat pipes crossing two stacks of aluminum fins. The air flow is provided by a duo of 90 mm and 80 mm fans. Their particularity is to turn in an opposite direction to each other. We finish with a nice backplate used to stiffen the card.
In terms of frequencies, we have the right to a factory overclocking since the card displays a boost to 1815 MHz. The memory on its side runs at 14 Gbps, so it does not benefit from factory overclocking.
The connectivity consists of two DisplayPorts 1.4a and two HDMI 2.1. For the power supply, a 6-pin PCIe socket and a second 8-pin socket are required.
As for the price, it should be around $900 according to our colleagues.
Gigabyte’s datasheet is here!
