Rocket Complex: a new vertical ITX case from Kolink!
Small novelty at Kolink which is in the continuity of the Rocket Heavy. Indeed, the brand announces its Rocket Complex, a case in ITX format with a perforated front panel with hexagons.
Rocket Complex: vertical ITX with a nice front panel!
Kolink Rocket Complex With this new model, Kolink offers us a case that will only accommodate mini-ITX motherboards. Of course, we find something compact with dimensions of 214.5 (W) x 212.5 (D) x 448.5 (H) mm. The weight is also very contained: 4.45 kg on the scale.
Inside, the brand offers us the possibility to install interesting configurations. We are thinking especially of the graphics card, which can measure up to 33 cm and 2.8 slots thick. Similarly, the brand provides a PCIe 4.0 riser by default for connecting the GPU. It must be said that the GPU takes place behind the motherboard tray.
For CPU cooling, we have two choices: either we switch to an AIO, in which case we have room for a 240mm radiator. For aircooling, we will be limited to 110 mm height, so be careful. Otherwise, the storage part benefits from four 2.5″ slots internally.
The case comes with a total of two 120 mm fans on the side panel. And unfortunately, we will not be able to install more given the format of this model.
Finally, we end with the power supply, which, as you might expect, will only accept SFX or even SFX-L format blocks.
For the bill, it amounts to 169.90 €.
Here is the technical sheet of Kolink !
