Review – NZXT Canvas 32Q Curved
A few weeks ago, we tested the NZXT Canvas 27Q. If you remember, in conclusion, we said we wanted to test the big brother, the Canvas 32Q Curved. NZXT noticed and as soon as a monitor was available, they kindly sent it to us.
Released at the same time as the Canvas 27Q, the 32Q Curved is obviously a bit larger. It’s still in QHD format, but this time it’s curved 1500R. This means that you should ideally stand at 1.5 meters from the monitor for a perfect visual comfort.
Starting at 379 $ + 50$ for the stand for the black model with stand, it is currently on promotion at 289 $, which is a reasonable price. Where NZXT is strong is that it is possible to choose the type of legs for its screen, or with a single or double arm, or even mix the colors.
Canvas 27Q specifications:
  • VA panel
  • A QHD resolution (2560×1440),
  • A P3 color coverage that reaches 90% (according to our tests).
  • A contrast of 1000:1
  • A viewing angle of 178
  • A refresh rate of 1ms
  • A frequency of 165Hz maximum
  • Freesync Premium, G-Sync Compatible
  • Anti-glare coating
  • VESA 100x100mm
  • 2 USB 3.0 ports
  • 1x DisplayPort 1.2
  • 1x USB C
  • 2x HDMI 2.0
Design
The NZXT Canvas 32Q Curved has a sober design, we are far from the gaming look. No RGB LED. The only fancy touch is the purple halo on the control nipple. However, we will notice the white stand with a black monitor, which is perhaps not the best choice.
RELATED STORY
RTX 4070Ti at more than 1000€?
NZXT Canvas 32Q Curved NZXT Canvas 32Q Curved NZXT Canvas 32Q Curved
Ergonomics
The mounting system is solid, the stand is stable and adjustable in height, as is the tilt. However, we will not be able to put the monitor vertically as we can on the Canvas 27Q. Finally, we have a VESA 100 mounting system. Also, you have access to a small USB hub under the screen.
NZXT Canvas 32Q Curved The OSD is simple, the presets are numerous. Everything is controllable with the nipple on the back of the screen. Or via the CAM application from NZXT, and the application is just perfect. NZXT Canvas 32Q CurvedNZXT Canvas 27Q
NZXT arms
We did not receive the single or double arm this time. But they appear to be exactly the same as those available with the Canvas 27Q. So they are very neat, with an all metal construction. NZXT Canvas 27Q NZXT Canvas 27Q
