Regis : a cube-shaped case at Azza !
We continue with a case from Azza. This is a truly original case since the brand announces a cube with its support. With the Regis, you can build a PC in the shape of a cube that levitates, cool no?
Regis : a cube-shaped case from Azza !
Azza Regis Contrary to what the miniatures suggest, this case is anything but compact. With this model, we must keep in mind that we are dealing with a model capable of accommodating motherboards in ATX format. This results in dimensions of 529 (D) x 481 (W) x 610 (H) mm. The same goes for the weight, which is anything but light: 12.5 kg on the scale.
Inside, the case is not really restrictive as to the dimensions of the components. You can opt for a 210 mm high CPU cooling unit or a 336 mm long graphics card in horizontal position. If you opt for a vertical installation, it will only be 320 mm long.
The interesting point is the ventilation, which is fully capable of receiving a 140 mm fan. On the sides, the brand announces two slots in 120/140 mm against one at the back. Nevertheless, this has an impact on the compatibility of watercooling radiators: 240/280 mm maximum.
Finally, we note the originality of the glass front with a lighting with an infinite depth effect like some pumps from NZXT. Similarly, this model comes with a support to give it a “levitating” side. The price is not cheap either since Azza positions it at $399,99 !
Here is Azza’s datasheet !
