Raven 4: Aerocool’s entry-level cooling unit!
Today, a small novelty from Aerocool with a small entry-level heatsink. The brand actually announces its Raven 4, a 120mm fan heatsink mounted on a very small heatsink. As you will see, the brand takes care of its product!
Raven 4: a 120mm fan mounted on a small heatsink!
Aerocool Raven 4
With this model, the brand announces a compact heatsink with dimensions of 125 (W) x 80 (D) x 135 (H) mm. However, as you can see, the fan has a cone-shaped frame. A shape that reminds us strongly of the Gammaxx 200T from DeepCool.
Anyway, the look is rather neat since the brand offers a completely black fan. Color that we find both on the aluminum fins and heatpipes. Moreover, the heatpipes are four in number, each with a diameter of 6 mm and come into direct contact with the CPU.
As for the fans, we find a 120 mm mill with aRGB lighting from the motor. For its part, the power supply is done through a 4-pin PWM type connector. At the level of speeds, it is a question of a range between 900 RPM and 1800 RPM while generating an air flow of 58 CFM for a static pressure of 1.6 mmH2O.
Finally, as far as installation is concerned, we have compatibility with LGA-1700 and other LGA-1000 sockets on the Intel side. On the AMD side, this Raven 4 will fit on AM4 as well as older platforms.
For the moment, no price, however, it should not go very high considering what is proposed here.
Here is the Aerocool datasheet!
