Raijintek offers its Cyclops AIOs with a flow indicator!
Raijintek is back with new AIO watercooling kits in the Cyclops series. This series will be available in 240 and 360 mm, in white and black, for a total of four kits. However, the brand is taking up a fairly old concept, that of the flow indicator built into the pump. We saw this on the brand’s Orcus series, released 7 years ago!
Cyclops: new AIOs with flow indicators from Raijintek!
Raijintek CyclopsWith these kits, Raijintek is offering us AIOs with a special design: the pump block incorporates a flow indicator. This indicator takes the form of an internal propeller that turns faster or slower depending on the speed of liquid flow inside the kit. It’s a design we haven’t seen for a long time… Manufacturers being busier installing screens all over the place!
As for the radiator, there are no surprises: it is made of aluminium and is a standard 27 mm thick. What’s more, the brand’s technical data sheet is pretty comprehensive. It even indicates the quantity of liquid included in the kit: 210 ml in 360 mm compared with 145 ml in 240 mm!
As for the pump, we know that it will operate at up to 4000 rpm. At full speed, it delivers 132 l/h, with a water column of 2 m! The cold plate is obviously made of copper, yes, but nickel-plated copper. The brand indicates that it measures 53.9 x 53.9 mm, while its height is 3.5 mm. Of course, this will cover the IHS of an Intel and AMD CPU in LGA-1000 and AM5.
Finally, the ventilation is provided by two or three 120 mm fans. These have a speed range of between 400 and 2200 rpm. At full speed, the airflow generated is 67.38 CFM, while the static pressure is 2.57 mmH2O.
For the moment, we don’t yet know the selling price!
Click here and here to see the Raijintek product sheets!
