The German brand be quiet! has announced the arrival of two new power supplies. These belong to the Pure Power 11 FM series, a range that is growing with the addition of these 850W and 1000W units.
Pure Power 11 FM : 850W and 1000W power supplies complete the range !
For the record, this power supply series already includes 550W, 650W and 750W power supplies. These new 850W and 1000W models complete the current series with higher power ratings. It must be said that with the increase in consumption of certain components, this is not a bad idea!
In the program, we find fully modular blocks taking advantage of an 80+ Gold certification ! As far as cooling is concerned, this task is entrusted to a 120mm SilentWings type mill capable of going up to 2000 RPM if necessary.
Internally, this block features an LLC design and has a DC-to-DC converter. Similarly, be quiet! uses a synchronous rectifier for better efficiency. Moreover, these power supplies have two 12V rails, one of 40A and a second of 36A in the case of the 850W power supply. Concerning the 1000W power supply, these rails are 46A and 42A.
Finally, the connectivity will be largely sufficient to power recent configurations. These two models have two EPS12V, one 8-pin and a second in 4+4 pins. For the graphics cards, we have four PCIe 6+2 pins for the 850W version against six for the 1000W reference.
The prices are also known since be quiet! positions the smaller of the two at 124.90 € against 154.90 € for the 1000W. Finally, availability is set for February 8 and the warranty is 5 years!
Here is the technical data sheet of be quiet!
