P30 Air, Zalman’s new BTF and Project Zero compatible case
A new case from Zalman: the P30 Air, airflow-oriented cases with mesh panels. These are also compatible with BTF and Project Zero motherboards – motherboards with no visible connectors!
P30 Air: another BTF and Project Zero compatible case!
Zalman P30 AirThis compact case measures 230 (W) x 452 (D) x 420 (H) mm. It weighs in at just 7.6 kg.
These compact dimensions mean that the case will only be compatible with ITX and micro-ATX motherboards. What’s more, the motherboard tray makes it compatible with BTF and Project Zero boards, motherboards with no visible cables!
Otherwise, the case benefits from good component compatibility. These include graphics: 392 mm, CPU cooling: 181 mm and power supply: 226 mm.
As for watercooling, there’s also compatibility with 360 mm radiators that can be mounted at the top.
As for ventilation, by default this model offers three 140 mm aRGB fans. Nevertheless, there’s enough space to fit up to nine 120 mm fans.
No price yet, but the P30 with tempered glass panels is on the market for around €80.
Here’s the product sheet!
