P12 PWM PST aRGB White: Arctic’s fans come in white!
After announcing its fans P in 140 mm with RGB lighting, the brand continues to develop its fans. This time, it is the 120 mm versions, with lighting, but in white. In short, the Swiss brand announces its P12 PWM PST aRGB White!
P12 PWM PST aRGB White: the same, but in white!
Arctic P12 PWM PST ARGB WhiteVisually, the fan does not change except for the color that goes to full white. Indeed, the frame is based on the shape of BioniX with silentblocks at the four corners. For the blades, we count five very stretched and joined to each other with an inner ring.
The connectivity will include two cables, a PWM male and female and a second aRGB also male and female for lighting management.
In terms of features, we find semi-passive fans with a rotation range between 0 RPM and 2000 RPM. At full speed, the airflow will be 48.8 CFM and the static pressure will climb to 1.85 mmH2O.
For the availability, know that these mills are proposed to the sale in the unit or in value pack of three. For the price, count 41,99 € in pack against 15,99 € in the unit. The guarantee does not change: 6 years. To get an idea of their performance, you can find our test of the black models at to this address.
This way to the Arctic data sheet!
