NX700: Antec case with two 185 mm fans in front!
Antec has announced its NX700, a new reference in the medium tower format. Nevertheless, this model is distinguished by its mesh façade and by the size of the fans installed. Here, we are talking about 185 mm mills!
NX700: two 185mm fans for the Antec case!
Antec NX700We start with the dimensions of this model which are 220 (W) x 440 (D) x 492 (H) mm. As for the weight, announces 6.7 kg, nevertheless, we have a glass panel and a steel chassis.
Internally, nothing original with an ATX, micro-ATX and mini-ITX compatible motherboard slot. This model has 7 expansion slots for daughterboards that can reach a maximum of 340 mm. Regarding the CPU cooler, we have a space of 170 mm and 200 mm for the power supply, 365 mm without the HDD cage.
In terms of cooling, this model is rather well equipped since we have two fans of 185 mm in front. Especially since they should breathe well thanks to the mesh front. Finally, a last mill in 120 mm is present at the rear of the case. As for the watercooling, the Californian brand announces a radiator support in 360 at the front. At the top, it is reduced to 280/240 mm at most.
We end quickly with the selling price of this model which is 84.99 € officially.
This way to the technical data sheet of Antec!
