MX600 Max RGB: two 200 mm fans for this Cougar case
From Cougar, we learn that the brand is launching a new case with its MX600 Max RGB. In addition to its attractive design, with its mesh grille on the front panel, the case features a powerful ventilation system consisting of two 200 mm mills on the front panel. Clearly, they have the power to efficiently ventilate the inside of the tower!
MX600 Max RGB: a new case for Cougar!
An internal baffle to channel airflow over the GPU!
Cougar MX600 Max RGB
The dimensions of this new case are 235 (W) x 482 (D) x 514 (H) mm. Internally, we find compatibility with ATX motherboards, while support for models with inverted connectors is also on the agenda.
As for the rest of the components, we’ll mention support for 400 mm-long graphics cards and 170 mm-high CPU fans. As for power supplies, we’re talking about support for 200 mm-deep blocks. In addition, the power supply cover is extended by a deflector, the purpose of which is to channel airflow over the graphics card. The graphics card also features a dedicated horizontal support.
Powerful ventilation as standard!
While we’re on the subject of ventilation, we’d like to point out that the case comes with two 200 mm front-mounted fans as standard. They are rather slow with their 1000 rpm, but the airflow will reach 140.4 CFM. Otherwise, a small 120 mm fan closes the rear.
With this, we find five other 120 mm slots, three on the top and two on the power supply cover. As for the watercooling radiator support, it will be possible to mount a 360 mm model at the top.
Price still unknown:
[affilizz-publication id=”e2flitg”]
Unfortunately, the retail price of this case is not yet known. We know that white and black versions are planned, but that’s all. Moreover, the MX600 non-Max RGB already sells for around €100 to €120, so this one should be in the same price range, if not a little more expensive.
Here’s the Cougar product sheet!
