Model 4: a 35l case from Geometric Future
Geometric Future continues to roll out its PC cases. Following on from the Model 6, Model 8 and Model 2, the Model 4 King Arthur is now available. This reference can accommodate an E-ATX motherboard in a volume of just 35l!
Model 4: a mini-maxi reference!
Geometric Future Model 4This model is available in two finishes: black/yellow and white. A third finish, Caliburn, is also available, and we think it’s much classier. The case is entirely black, with a mirror and glass front panel.
The other interesting thing to note is the compatibility with E-ATX motherboards in a volume of just 35l. This reference measures 215 (W) x 410 (D) x 395 (H) mm.
This high compatibility with motherboards and low volume are made possible by the position of the power supply unit in the case. It can be installed either vertically or horizontally (depending on its depth) behind the front panel. Note that the PSU will be limited to a depth of 180 mm vertically, as opposed to 150 mm horizontally.
Geometric Future Model 4 Caliburn
As far as cooling is concerned, the case is compatible with 240 mm and 360 mm watercooling radiators. The 360 mm can be mounted at the bottom, depending on the layout of your components. The 240 mm will be mounted at the top of the case. Alternatively, the ventilation can accommodate up to six 120 mm fans: three at the bottom, two at the top and one at the rear.
Finally, the case integrates a number of features. A hinged panel with screwless opening. Two vertical expansion slots are provided for graphics cards. The CPU cooler can reach a height of 164 mm, while storage can accommodate three 2.5″ or 2x 3.5″ 1x 3.5″ units.
As for the price, it won’t even be that expensive: $99 in black and $109 in white!
Here’s the Geometric Future product sheet!
