Mobius 120: a new series of fans from Cooler Master
Cooler Master announces the arrival of new fans in its catalog. Indeed, the brand offers us its new Mobius 120 fan. These models are in 120 mm and have or not an aRGB lighting. Nevertheless, you will see, the characteristics are not the same, whether or not lighting is added.
Mobius 120: fans with or without lighting!
Cooler Master Mobius 120On the program, Cooler Master announces fans with interconnected blades. The objective is to improve the stability and balance of the fan. The objective behind all this: to reduce parasitic vibrations as much as possible. The same goes for the motor, with a design that allows constant oil return to the bearings. For the brand, the objective is to improve the life of its product.
Otherwise, from a characteristic point of view, we will retain two cards depending on the model. Thus, the non-RGB version will be slower than the bright model. Indeed, it will be necessary to count on a range of rotation included between 0 RPM and 2050 RPM. At full speed, the static pressure will reach 2.69 mmH2O and the air flow will rise to 63.1 CFM.
The RGB model has a much higher speed: 0 RPM to 2400 RPM. In fact, the static pressure rises sharply: 3.63 mmH2O, and the air flow is the same, at 75.2 CFM.
The bill will still be substantial with a unit price of 24.99 € without RGB against 28.99 € with.
Here and there the technical data sheets of Cooler Master!
