Cooler Master announces a new keyboard model with its MK721. This is a compact keyboard with a wide choice of connectivity. Basically, it can be used on any system… Or almost!
MK721: a 65% model with PBT keys!
With this new model, Cooler Master continues to offer us compact keyboards. Indeed, this model arrives in a 65% format. Overall, we keep only the alphanumeric area, but we add the navigation arrows. The page up, page down and supr. keys are also present. This makes navigation easier. We also note the presence of a wheel for the management of sound.
Besides that, Cooler Master uses qualitative materials. We will note the presence of an aluminum faceplate with a plastic base. However, what will hold our attention are the PBT keycaps, much more resistant to wear.
As for the models CK352 or SK622 models, for example, the brand continues to source the switches from TTC. The choice is between linear (red), clicky (blue) and tactile (brown) models, the classic choice.
Otherwise, as far as connectivity is concerned, we can either use USB, classic, or wireless. Here, we will have the choice between 2.4 GHz Wifi and Bluetooth. Moreover, wireless also means battery and the latter displays 2000 mAh, enough to last 73 hours without RGB LEDs.
Finally, the availability is set for March and the price is £129.99 or about 150 € to 160 €.
Here is the Cooler Master datasheet!
