Mirage Gold: RGB power supplies from Aerocool!
The Aerocool brand announces the arrival of new power supplies with its Mirage Gold series. It is a question of a total of six new power supplies declined with a modular and non-modular management of the cables.
Mirage Gold : 650W, 750W and 850W power supplies !
Aerocool Mirage Gold With this new range, the brand offers a series of six new power supplies with power ratings of 650W, 750 and 850W for the largest. However, this series is divided into two categories: modular blocks and non-modular power supplies with a more attractive price… In theory.
Otherwise, the series highlights a neat design, with a side part equipped with RGB lighting. It will be controllable through a three-pin ARGB cable directly attached to the power supply.
Internally, the brand indicates to use Japanese capacitors in 105°C. Otherwise, we find a circuit of conversion of voltages DC-to-DC and an active PFC. Regarding the performance, the brand highlights an 80+ Gold certification. Regarding the protections, we find: the OVP, the UVP, the OPP, the SCP, the OCP, etc. Finally, the cooling is ensured by a 120 mm mill with active operation.
As far as cables are concerned, there are enough to supply modern configurations since all the blocks feature two EPS12V 4+4 pins. The PCIe part has three 6+2 pin connectors (against two in 650W) as well as eight SATA and four Molex. The 650W blocks make do with six SATA and three Molex.
For the moment, no price or availability date.
This way to the Aerocool datasheet !
