Liquid Freezer III Pro 280 and 420 from Arctic!
Last March, the Swiss brand Arctic announced new all-in-one watercooling kit with its Liquid Freezer III Pro series. This series was launched with a 360 mm model only, although available in black and white versions with or without RGB. Today we learn that the series has been completed with a 280 and 360 mm radiator.
Liquid Freezer III Pro, 280 and 420 mm versions!
Arctic Liquid Freezer III Pro 420With this series, the brand offers watercooling kits that are particularly aggressive from a pricing standpoint. Indeed, the price tag reaches €140.99 in 420 mm, and €120.99 in 280 mm, which is particularly aggressive, especially when compared with Corsair or NZXT. With these two new kits, the brand completes its series initially launched in 240 and 360 mm. However, Arctic’s heat exchangers and radiators are particularly thick: 38 mm vs. the usual 27 mm. This is something to bear in mind, especially if you have a compact housing. Pump mounting is also interesting, since depending on your Intel or AMD socket, you can mount the pump offset. This way, the cold plate is perfectly positioned on the hot spot of a Ryzen 3000/5000/7000/9000 or Core Ultra 200 CPU. What’s more, for mounting on Arrow Lake, Arctic offers its own contact frame to minimize deformation of the CPU‘s IHS .Arctic Liquid Freezer III Pro 280Here, the fans evolve and the brand opts for its new P14 Pro fans, recently launched on the market. In their 140 mm version, these fans run at up to 2,500 rpm and generate a significant airflow. We’re talking about 110 CFM with a static pressure peaking at 5.2 mmH2O, enough to get through the AIO‘s thick radiator. As for availability, we’ll have to be patient before the series is fully available on the market, but we can already find the 280 at €87 on Amazon, compared with €107 for the 420 mm!
Arctic product sheets here and here!
