LiqMaxFlo: Enermax AIOs with Arctic-style fans!
A new series of watercooling kits from Enermax. The brand has announced its LiqMaxFlo series, consisting of six AIO kits with RGB or non-illuminated fans. In any case, the ventilation reminds us strongly of Arctic’s P12 and P14!
LiqMaxFlo: watercooling from 120 to 420 mm!
Enermax LiqMaxFlo
The radiator is 38 mm thick
With its kits, the Enermax brand offers us a number of AIOs, with six variations in all. However, the non-RGB versions are not just “silly” RGB versions without lighting, no, they’re not. If you look at the technical data sheets, you’ll quickly realize that the sizes and thicknesses of the heat sinks change. To put it simply, we have :
  • RGB fans:
    • 240 mm, 360 mm and 420 mm with a 38 mm thick radiator!
  • Non-RGB fans:
    • 120 mm, 240 mm and 360 mm with a 27 mm thick radiator!
As far as the pump is concerned, the company highlights a 60 mm fan integrated into the top of the cover. This will be used to cool the components around the socket. In addition, a detachable magnetic cover that can be rotated in 90° increments has been added for a more aesthetically pleasing appearance. The Enermax logo will always be facing the right way.
Enermax LiqMaxFlo SR
Here, it’s just 27 mm thick
Otherwise, the company highlights a dual-chamber design for its pump. According to the company, this allows temperatures to be reduced by 8°C compared with the previous generation of watercooling kits.
Ventilation is provided by five-blade fans, very similar to Arctic’s P12 and P14. The blades are thick and strongly curved. As for their characteristics, whether RGB or not, they share the same datasheet, which is as follows:
  • 120 mm :
    • Speed: up to 1800 rpm
    • Air flow: up to 58.03 CFM
    • Static pressure: up to 2.4 mmH2O
  • 140 mm:
    • Speed: up to 1700 rpm
    • Air flow: up to 78.76 CFM
    • Static pressure: up to 2.71 mmH2O
As for assembly, the kits will be compatible with LGA-2000/1700/1200/115x/1366 as well as AMD AM4 and AM5 platforms.
Enermax product datasheets here!
