Lancool 205M Mesh: a new µATX case from Lian Li!
Lian Li announces a new case on the market with the Lancool 205M Mesh. It is a micro-ATX case with a mesh front panel and two 140mm fans.
Lancool 205M Mesh: the latest from Lian Li!
Lancool 205M MeshWith this new case Lian Li announces a reference in compact format measuring 210 (W) x 402.5 (D) x 400 (H) mm. As for the materials, we have the right to tempered glass and steel for construction.
Inside, we have enough space to accommodate a micro-ATX or mini-ITX motherboard. The graphics card benefits from a clearance of 350 mm while the CPU cooling unit is 160 mm high. Finally, the power supply benefits from 180 m depth.
The storage will take place in a hard disk cage located under the power supply cover. The latter benefits from 3.5″/2.5″ baskets.
The basic ventilation comes with two 140mm aRGB mills at the front. It will be possible to add two 120 mm fans at the top and one at the back. Moreover, the support of watercooling radiator remains basic with 240 mm in the top and in front.
For the price, it will be necessary to count 74,90 € in black and 79,90 € for the white version!
Here is the technical data sheet of Lian Li !
