Kone XP : a Roccat mouse with transparent and RGB top !
Roccat announces the arrival of a new mouse with its Kone XP. Globally, it is a rather imposing model with a look that will attract the eye. Indeed, it offers a translucent and illuminated upper part.
Kone XP : a semi-translucent mouse !
Roccat Kone XP With this model, the Roccat brand completes its Kone series. The mouse has dimensions of 76 (W) x 126 (D) x 40 (H) mm. As for the weight, it is not a “featherweight” model either, with 104g on the scale. If you like your mice a little heavier, you should appreciate this model.
Internally, the brand opts for an optical sensor called Owl-Eye that can go up to 19,000 DPI. In fact, it is a sensor based on the PAW3370 from PixArt. Moreover, for the left and right clicks, there are Titan optical switches with a lifetime of 100 million activations.
Otherwise, in addition to its translucent upper part with a strong RGB color, there are a lot of buttons. In addition to the usual right and left clicks, we have five buttons under the thumb and two others accessible via the index finger. In short, via the EasyShift, we have a total of 29 possibilities for programming macros.
We finish now with the price which is displayed at 89.99 € on the site of Roccat!
Here is the technical data sheet from Roccat !
