Jonsbo unveils its U4 pro case!
Jonsbo announces new cases with its U4 Pro. This series is available in a black model and a second white one. Finally, we will have the choice between glass or perforated side panels to let the configuration breathe a maximum!
U4 Pro: four cases from Jonsbo!
Jonsbo U4 Pro Noir
With this new series, the brand announces cases in medium tower format. These measure 205 (W) x 395 (D) x 426 (H) mm, rather compact for the format. Otherwise, we are dealing with a construction combining steel and aluminum. Ditto, their particularity, offer rounded edges.
Inside, the case offers enough space to accommodate a motherboard in ATX, µATX and mini-ITX format. The power supply has a clearance of 170 mm to 190 mm, while the graphics card has a clearance of 280 mm to 330 mm. Finally, the CPU cooling unit should not exceed 160 mm in height.
Jonsbo U4 Pro
There are some constraints in terms of ventilation since we will be limited to a total of five fans in 120 mm. Indeed, two slots are available in the top and bottom while the last one will be present at the back of the case. As for the watercooling, we will be limited to 240 mm radiators.
For the price, it is difficult to say how much the bill will be. On the other hand, you should know that the Plus version is negotiated around 110 € by us as we can see on our comparator.
Here are the technical data sheets of Jonsbo!
