ID-Cooling offers its AIO Space LCD with integrated display
A new series of watercooling kits from ID-Cooling: the Space LCD. This is a new series of kits featuring an LCD display on top of the pump. As usual, the focus is on monitoring and customization.
Space LCD: four AIOs with LCD displays!
ID-Cooling Space LCDThe series comes in two sizes, with 360 mm and 240 mm radiators. Two colors are also available: white and black. Finally, the special feature is a 2.1″ LCD screen with 480×480 resolution and 600 cd/m² brightness. This can be used to display various system-related information, as well as video files, .gif or .jpeg images.
Ventilation is provided by two or three 120×27 mm fans running at up to 2000 rpm. At full speed, the airflow is 78 CFM at a static pressure of 2.68 mmH2O. Just keep an eye on the noise generated.
As for the rest, we’ll mention the RGB lighting on the fans. Otherwise, the pump boasts a copper base and a speed of up to 2,500 rpm. It can be installed on LGA-2000/1700/1200/115x sockets and AMD AM4/AM5 platforms. Last but not least, the kits manage TDPs of 300W at 240mm, versus 350W at 360mm.
Prices are rather affordable, given that they include a display. You’ll need to reckon with $139.99 for 240 mm and $179.99 for 360 mm.
Here are the ID-Cooling product sheets!
