I70C & I70: two small Cooler Master top flows in 120 mm!
Cooler Master attacks the entry-level cooling market with two new references. The brand announces its I70C and I70 models, two small 120mm fans with a top flow design and a basic radiator.
I70C and I70: one with RGB and the other without!
Cooler Master I70CIn the program, we find two small heatsinks equipped with fans in 120 x 25 mm. The heatsink itself also has compact dimensions of 120 (W) x 120 (D) x 60 (H) mm. Normally, there should be no concern about compatibility with even the most compact cases.
However, the “C” version has a little something extra that the other model does not have: a copper base. Otherwise, we find a structure made of aluminum fins directly machined in the mass.
Here, there are no copper heat pipes in particular. For compatibility, these two products are intended only for Intel sockets. The list of compatible platforms includes: LGA-1700/1200/115x. Cooler Master I70 On the fan side, we find a model operating at up to 18800 RPM. At full speed, the air flow will reach 37 CFM while the static pressure will be 1.33 mmH2O. Finally, we will remember that the “C” version also benefits from an RGB lighting.
The prices are still unknown!
Here and there the technical data sheets of Cooler Master!
