HyperX announces its Pulsefire Haste 2 mouse in wired and wireless!
HyperX announces a new mouse with its Pulsefire Haste 2, a model that comes in wired and wireless versions with battery. Moreover, the model of the brand has for principle to be lightweight with a light weight!
Pulsefire Haste 2: a wired and wireless mouse!
HyperX Pulsefire Haste 2With its new mouse, the brand offers a model measuring 124.3 (W) x 66.8 (D) x 38.2 (H) mm. It will not be very heavy since in its wired version, it weighs 75g including cord. Next to that, the wireless model is 60g, 83g with the cable. If the shape can make think of an ambidextrous model, it will not be totally because of the presence of additional buttons on the left of the shell.
In any case, we are dealing with a fairly sober model with an RGB lighting at the level of the wheel.
Internally, it is equipped with an optical sensor HyperX 26K offering a sensitivity reaching 26000 DPI. The latter is therefore able to withstand accelerations of 50G and offers a speed of 650 IPS.
With this, we find HyperX Switch house switches offering a lifetime of 100 million activations. However, the internal memory will only allow to save one and only one profile. Finally, the polling rate will be 1000 Hz for the wireless mouse and 8000 Hz for its wired version.
We also note that the wireless model has an internal battery of 370 mAh offering a maximum autonomy of 100 hours.
HyperX Pulsefire Haste 2 accessoires
HyperX also distinguishes itself from its competitors by offering a complete accessory part. In the box, we find a set of rubberized grips improving the grip of the shell. Finally, if necessary, we can change the pads because a spare set is also present!
All that remains is to talk about the price which is $59.99 for the wired version against 89.99 € for the battery model.
Here and there the technical data sheets of HyperX !
